2002 BMW 330 Service Engine Soon Light
MMCKERNS
I have a 2002 BMW 330Ci. My yellow "service engine soon" came on a couple of weeks ago and hasnt gone off since. I haven't rushed into the shop because the car runs the same as it did the day before the light went on...great. I also notice that the yellow Oil light has been coming on intermittently (about 3-4 times in the past 2 weeks for no more than 10 seconds while driving). The oil level is fine...i even topped it off and the yellow oil light came on again. Any ideas???
Apr 23, 2007 at 9:33 AM
DOCHAGERTY
  • 9,606 POSTS
the check engine light can be on for any number of reasons,a scan tool will be needed to pinpoint this issue.as for the oil level lamp there is a bulletin on this issue.the repair sometimes requires replacement of the oil level sensor and recoding the lamp control module.if you have checked the oil level and it is nominal,you may ignore this warning light at your own risk.
Jul 22, 2007 at 4:44 PM
Suggested Repair
Scan the Service Engine Soon light to identify the fault. If the oil level is confirmed normal, the intermittent oil warning may require replacing the oil level sensor and recoding the lamp control module per the related bulletin. Ignoring that warning is at the owner's risk.
Conversation Summary
The owner of a 2002 BMW 330Ci reports a persistent Service Engine Soon light with no change in how the car runs, plus a brief intermittent yellow oil light despite a normal oil level. The expert says a scan tool is needed for the check engine light, and the oil warning may require oil level sensor replacement and lamp control module recoding.
