2002 BMW 330 Service Engine Soon Light
MMCKERNS
I have a 2002 BMW 330Ci. My yellow "service engine soon" came on a couple of weeks ago and hasnt gone off since. I haven't rushed into the shop because the car runs the same as it did the day before the light went on...great. I also notice that the yellow Oil light has been coming on intermittently (about 3-4 times in the past 2 weeks for no more than 10 seconds while driving). The oil level is fine...i even topped it off and the yellow oil light came on again. Any ideas???
Please note that I posted a dontation this morning. Receipt Number: 3936-1854-2910-1860
May 4, 2007 at 6:15 AM
MERLIN2021
  • 17,250 POSTS
The oil light is automatic to tell you it's time for an oil change, soon it will stay on, the MIL is telling you the PCM has detected an engine sensor issue...get the codes read before you create a larger problem from a small one!
May 7, 2007 at 10:13 AM
BIMMERBOY2001
are u sure there arent any oil leaks??make sure ther arent any leaks ..mybe gaskets round 600$ to fix.
Dec 25, 2009 at 6:46 AM
MERLIN2021
  • 17,250 POSTS
bimmerboy, did you check the date of this post? It's from Mat 2007! Issue must be resolved by now!
Dec 26, 2009 at 10:17 PM
Suggested Repair
Have the Service Engine Soon codes read to identify the detected sensor fault before it worsens. If the oil level is correct, treat the intermittent yellow oil light as an oil-service reminder and change the oil before it stays on. Check for leaks only if the oil level drops.
Conversation Summary
The owner of a 2002 BMW 330Ci reported a persistent Service Engine Soon light and a brief intermittent yellow oil light despite a correct oil level. An expert said the oil light is a service reminder and the engine light indicates a sensor fault, so the codes should be read promptly. A later comment suggested checking for oil leaks and gasket repairs, but the expert noted the original post dated from 2007 and was likely already resolved.
