2001 BMW 330i Tail Lights Out
CARMINE
Hello!
I have a 2001 BMW 330i with 105,000 miles with a 6 cyl engine.
The rear tail and brakes lights are no longer working. At first the brake lights stopped working one by one. Now no tail lights work at all except the license plate and truck lights.
I have checked the fuses and bulbs themselves and they appear fine. Can you please help me?
Thank you!
Carmine
Sep 10, 2007 at 6:55 PM
DOCHAGERTY
  • 9,606 POSTS
Remove the connectors at the rear light assemblies and inspect for corrosion and melted plastic at the connectors and the tail light assemblies
Sep 11, 2007 at 3:19 PM
AJITVERMA
  • 5 POSTS
We had similar problem with the 2003 model and
had to replace the lighting control module.
Oct 12, 2008 at 3:44 PM
JIMBOW
I had a similar problem but with just one taillight. After several trips to the dealer who replaced the bulb each time which subsequently went out again after a few days, I took it to a local repair shop and he identified a loose ground wire. Without going through to entire electrical system to fine the loose wire, he just added a ground wire and the lights have been fine now for 3 years.
Oct 29, 2008 at 6:49 AM
Suggested Repair
Remove the rear light assembly connectors and inspect the connectors and lamp assemblies for corrosion and melted plastic. If those are sound, also check for a poor ground and consider the lighting control module, which other owners reported as related fixes.
Conversation Summary
A 2001 BMW 330i owner reported that the rear tail and brake lights stopped working, while the license-plate and trunk lights still worked. Fuses and bulbs appeared fine. An expert advised removing the rear light connectors and inspecting them and the assemblies for corrosion and melted plastic. Other owners reported similar issues resolved by replacing the lighting control module or adding a ground wire.
