2004 BMW 330 DDE light on
2004 BMW 330
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
RJHARRIS
the dde light is on constantly. The car runs well, but the light never goes off.
Can you suggest where to look please?
Thanks.
Jun 17, 2008 at 8:37 AM
DOCHAGERTY
  • 9,606 POSTS
Please repost with the vehicle identification number.
Jun 17, 2008 at 8:42 AM
RJHARRIS
Sorry, not sure what you mean by vehicle identification number? Its a 330D E46 if that helps?
Jun 27, 2008 at 1:02 AM
DOCHAGERTY
  • 9,606 POSTS
The VIN is the 17 digit number that is located on the "b" pillar at the drivers door or on a plate that is visible through the windshield. The light may be on due to a plausibility issue or a fault in a sensor or for an emission problem. A scan of the car with the BMW proprietary software should reveal the fault.
Jun 27, 2008 at 3:27 AM
RJHARRIS
I got a guy with the diagnostic scanner to have a look,
there were hundreds of faults registered!
He was able to reset the light and all seems ok now.
He says it may have had a low battery at some point.
Hope this might help someone else with a similar problem.
Jun 27, 2008 at 8:22 PM
DOCHAGERTY
  • 9,606 POSTS
The issue with most of the faults with todays BMW cars is that they are excessively dependent on computers and the electronics that require steady voltage. You get a spike or a voltage excursion and it sets faults. And the only way to know for sure is to scan for faults and be able to correctly interpret them.
Jun 28, 2008 at 1:17 AM
