2003 BMW 325 RE: White smoke from the hood/burning rubber s
80,000 MILES • 6 CYL • FWD • AUTOMATIC
GEORGE.IOANNOU
I recently went away and parked the car in the garage for 10 days. When I drove the car on the 11th day I noticed some smoke coming from the hood and it smelt like rubber burning. I checked the pin and it was level, no car lights came on and there were no oil leaks. (I also checked to see if a grocery bag got caught under neath)
To be safe I took it into a local mechanic and they told me that if the needle is level and there is no leaks there is nothing to worry about and perhaps some moisture came into the valves which caused the smoke. I drove the car after for a couple of days with no issue.
Over the weekend I had the car parked in the garage . I took the car out after 2 days parked for about 20 min. and when I returned I parked the car in the garage and I noticed some smoke coming from the hood and the smell of burning rubber. I did all the above checks and saw nothing unusual. Its obviously something. Can you help?
Oct 19, 2010 at 12:46 AM
DR LOOT
  • 2,311 POSTS
I'm having a hard time understanding your position, if you can see the smoke is it on the right side of the engine on the left side? that is critical if it's on the right side I have a few ideas if it's on the left side I have no idea tell me which side of the engine compartment the smoke is coming from
Oct 29, 2010 at 3:40 PM
