1986 BMW 325
168 MILES • 6 CYL • 2WD • MANUAL
SOCALJEEP
My 1986 325 blows black smoke and wont run at low RPM's, but does not act this way all the time. It at times will run fine and them start running rough and blow black smoke. The engine doesnt burn a drop of oil. What do you think?
Thanks
Jul 12, 2008 at 2:47 AM
DOCHAGERTY
  • 9,606 POSTS
The air flow meter is at the heart of how much fuel is injected and it might require replacement. You did not mention any history of the service and I usually try to get as much information as possible before making any recommendations.
Jul 12, 2008 at 6:10 AM
SOCALJEEP
Thank you for your reply. I think I have solved the problem but would like to know your opinion. The rubber air hose that connects from the air box to a plastic fitting next to the fan/shroud had become disconnected. I reattached the larger (4-5") rubber hose to the plastic fitting so the sensor is not getting hot engine compartment air. I believe with the hose not properly attached, the air box was pulling in the higher temp engine compartment air and adjusting the mixture accordingly. Do you believe I am correct? The car is running fine now! Should I continue to investigate? A little history on the maintnance, I had kept the car properly maintained wiith 168K miles. The care does not burn a drop of oil and is mechanically sound. Thanks for your reply.
Joel: alaskaflyfishing@verizon.net
Jul 12, 2008 at 6:47 AM
DOCHAGERTY
  • 9,606 POSTS
Sounds like you fixed it mate, good on ya!
Jul 12, 2008 at 9:18 AM
SOCALJEEP
Thanks for your help Doc!
Jul 12, 2008 at 11:47 AM
SOCALJEEP
I have another question for you if you dont mind. The "factory"cruise control in the 1986 325 has stopped working. Do you have any suggestions?
Thanks again for your input!
Joel
Jul 14, 2008 at 7:57 AM
DOCHAGERTY
  • 9,606 POSTS
It might be several things that can keep the cruise control from functioning properly. It could be a broken trace on the circuit board in the instrument cluster or even a blown fuse. It can be a broken servo cable or no tempo input from the instrument cluster. If the cruise control is that important to you I recommend seeking out local professional help.
Jul 14, 2008 at 2:02 PM
