I've replaced my distributor cap, rotor and coil and yet I still have no spark. I was wondering if it has anything to do with an angle sensor?
Jun 25, 2007 at 3:16 PM
There is no angle sensor on this engine. Check the crankshaft position sensor, which is located on the front timing cover.
The owner of a 1990 BMW 325i still has no spark after replacing the distributor cap, rotor, and coil, and asked whether an angle sensor could be the cause. The expert said this engine has no angle sensor and identified the crankshaft position sensor on the front timing cover as the related sensor to check.
