thank you will have to have it checked out. it finally did turn over. 1st try, it wouldn't budge, then it did turn, but was like something was in the column hitting it.
also, the car has had new pads and struts put on a couple weeks ago. along with some kind of 'clip' on the struts. however, i still get the light that comes on on the dash with the triangle & circle around it. when the light flashes on the dash, the car won't accelerate. it has gotten to the point that most of the time, i have to engage the ASC button to keep acceleration. the company that put the pads/struts on said that the sensor wires in the wheel area needed to be replaced. could this be the problem with the flashing triange light????
Feb 20, 2007 at 2:36 AM
