1995 BMW 320i No Fuel to Engine
DAMO429
  • 6 POSTS
1995 320i no fuel to engine problem dr hagerty sugested bad fuel pump and change the fuel filter.
he also gave me a part number which i put into google and found where the fuel pump was and how the tank is set up.
so what did i do
the fuel pump is under the rear passenger seat on the drivers side the fuel filter is under the front passenger seat (under the Car)
I disconnected the fuel line at the outlet side of the fuel filter. turned on the ignition nothing no fuel
removed the back seat and found the fuel pump
then i disconected the fuel line at the inlet end of the fuel filter put a coke bottle over it to catch any fuel and when i put the ignition on this time there was fuel in the bottle and i could hear the fuel pump
when i removed the fuel filter i blew through the middle or at least tried to it was almost blocked solid
i have put on a new filter but she still wont go
so now im thinking
is there a blockage some where along the injector rail
or the injectors
if so is this a big job will i be able to do it how do i do it
could there be a problem with the pump even though it apears to work ?
could there be a problem with the fuel acumulator if so how do i check
or is there something else i havent thought of
please help i am going to donnate when i get paid
Oct 10, 2007 at 10:32 AM
DOCHAGERTY
  • 9,606 POSTS
As pumps age during their lifespan, the ability to pump fuel diminishes. If the filter was plugged, I would recommend replacement of the pump to be sure.
Oct 10, 2007 at 5:12 PM
DAMO429
  • 6 POSTS
spott on mate replaced the pump today 40 quid from scrap yard works a treat she started after about
eight turns your a dimond
im chuffed too nuts i got it started i wanted a project and i got one noticed its leaking water but i dont know where from so ill be back
thanx again doc
Oct 12, 2007 at 9:04 AM
DOCHAGERTY
  • 9,606 POSTS
another happy BMW owner!!
Oct 12, 2007 at 11:53 AM
Suggested Repair
Replace the fuel filter if it is restricted and replace the aging fuel pump. A plugged filter and reduced pump output can starve the engine of fuel; a new pump restored delivery and the car started.
Conversation Summary
The owner of a 1995 BMW 320i had no fuel reaching the engine. Fuel appeared at the filter inlet and the pump could be heard, but the filter was nearly blocked. A new filter did not fix it. The expert said an aging pump can lose output and recommended replacing it after a plugged filter. The owner installed a used pump and the engine started after several cranks. A separate water leak was noted for later.
