1993 BMW 320i Overrevs Uphill
TREVORBMW
I OWN A BMW320I AUTO 1993 MODEL.WHILST DRIVING UPHILL ON DRIVE GEAR THE ENGINE SEEMS TO OVERREV AND THE CAR GETS STUCK IN GEAR.IT ONLY CHANGES BACK TO NORMAL WHEN I SWITCH OFF AND RESTART THE CAR.PLEASE HELP!
Sep 6, 2007 at 3:20 AM
  • 55,797 POSTS
is your car stick shift?
Sep 17, 2007 at 11:25 AM
TREVORBMW
NO.
Sep 19, 2007 at 6:07 AM
  • 55,797 POSTS
lets check the trans fluid level, and check the condition of the fluid. A transmission control seliond can cause this problem, also. You can try servicing the tranmission and see if that helps. If not you might be in the tank for a rebuilt trans.
Sep 19, 2007 at 8:14 AM
Suggested Repair
Check the automatic transmission fluid level and condition, then service the transmission. A transmission control solenoid can also cause this; if fluid service does not help, a rebuilt transmission may be needed.
Conversation Summary
The owner of a 1993 BMW 320i automatic reports that the engine overrevs and the car stays stuck in gear while driving uphill in Drive, returning to normal only after the car is switched off and restarted. After confirming it is not a manual, the expert advised checking transmission fluid level and condition, servicing the transmission, and considering a transmission control solenoid, with a rebuilt transmission if those steps do not help.
