1995 BMW 320i No Fuel to Engine
DAMO429
  • 6 POSTS
i have a 1995 bmw 320i 1800000 miles my car is regestering half a tank of fuel it cut out on me at traffic lights after a 20 minuite jurney with no warrning i think i can hear the fuel pump when you start the key but there is no fuel getting to the engine what could this be and what else could the sound from under the bonnet be it sounds like an electric motor
please help
Oct 8, 2007 at 11:39 PM
DOCHAGERTY
  • 9,606 POSTS
it sounds as if the fuel pump is bad
the part # is 16-14-1-182-842
I would also replace the fuel filter
Oct 9, 2007 at 2:26 AM
DAMO429
  • 6 POSTS
thanx man that confirmed what i was thinking but giving me the part number is spot on.As didnot where the fuel pump was.but i do now and i really need to know what that soud is as its got somthing to do with the fuel i was working on my car today trying to get the fuel filter off and i had the ignition on as i had just put two gallons of fuel in it just in case i had done the obviouse the ignition was on for agood 20 mins and that little pump was still going for it i could feel vibration in some of the pipes and i traced it back to a silver pump under the air intake for the injectors and is conected to that intake and a black plasic canister about as big as a beer can and the other side of that canister has a blue plastic pipe which i think goes to the fuel tank is that pump supposed to run constantly
Oct 9, 2007 at 12:44 PM
Suggested Repair
Replace the fuel pump (expert part number 16-14-1-182-842) and also replace the fuel filter.
Conversation Summary
A 1995 BMW 320i with about 180,000 miles cut out at traffic lights after a short drive despite showing half a tank, and no fuel was reaching the engine. The owner heard an electric-motor sound and thought the fuel pump was running. The expert said the fuel pump was bad, gave part number 16-14-1-182-842, and recommended replacing the fuel filter as well. The owner later found a silver pump under the injector air intake connected to a black canister and a blue line toward the tank; it kept running with the ignition on for about 20 minutes, but that follow-up was not answered.
