1991 BMW 320i Left Turn Shake
GOLFSHAQ
I have a 1991 BMW 320I. When i turn left going at about 30 40 MPH the left front wheel shakes causing the steering wheel to shake pretty bad. turning right there is no problem. I also notice that once the car is park there is oil leaking from beside the front wheel (left Front wheel only) any idea what this might be.
May 18, 2007 at 2:35 AM
SERVICE WRITER
  • 9,123 POSTS
Either you better Jack up that wheel and find the play or get it to a shop that will. Maybe loose wheelbearing or tierod is the first thing that comes to my mind. It doesn't sound safe in any event.
May 18, 2007 at 11:20 AM
Suggested Repair
Jack up the left front wheel and check for play, especially a loose wheel bearing or tie rod, or have a shop inspect it. Also find the source of the oil leak beside that wheel. Do not ignore it; the shaking is a safety concern.
Conversation Summary
The owner of a 1991 BMW 320i reports left-front wheel and steering-wheel shake when turning left at about 30-40 mph, with no problem turning right, plus oil leaking beside the left front wheel when parked. The expert advises raising the wheel to find play or taking it to a shop, suggesting a loose wheel bearing or tie rod, and notes it does not sound safe.
