1994 BMW 318
146,728 MILES • 4 CYL • FWD • AUTOMATIC
JMARTELL
The car was started and my dad pulled out the fuel pump relay switch out as the car was on and running. The car immediately stopped running and has not started since. Is it depressurized? Do I need a new fuel pump? Sensor? HELP!
Thanx!
J. Martell[img:f85e3e6002]http://www.2carpros.com/forum/automotive_pictures/134675_Candy_Lauder_2003_1.jpg[/img:f85e3e6002]
Dec 26, 2007 at 3:23 AM
DOCHAGERTY
  • 9,606 POSTS
The fuel pump can and does fail at the mileage you reported. It is in the tank and is accessed from under the rear seat, passenger side. Try tapping on it while cranking to start and it may come back to life. Replace even if it does work after tapping on it.
Dec 30, 2007 at 3:45 AM
