Thanks in advance for your assist...
1991 BMW 318 Stalls and Won't Start
Suggested Repair
The no-start was resolved by replacing the fuel relay and the main circuit relay. Also confirm the camshaft turns while cranking, since a failed timing drive can prevent starting; this engine uses a timing chain rather than a belt.
Conversation Summary
A 1991 BMW 318is with 183,000 miles stalled while highway driving and would only spin without starting after long storage. The owner confirmed the fuel pump hummed, could not identify the unlabeled fuel relay, and had recently installed performance ignition coils. An expert suggested checking whether the camshaft turned while cranking in case the timing belt had broken. The owner noted it has a timing chain and said a crankshaft sensor replacement did not help, but replacing the fuel relay and main circuit relay made it start.
