1993 BMW 318 warning light
1993 BMW 318
GIRLCAR
Electrical problem
1993 BMW 318 4 cyl Wheel Drive Type unknown Automatic 164000 miles
i believe my warning light for my brakes is on (circle with dashes wrapped around it- i have no manual to check)
anyway, my brake lights are out...i've replaced bulbs and no luck. about to change the fuse (hopefully, it's that simple of a problem) but if it is not...HELP.
what should i check next?
Dec 12, 2007 at 3:32 AM
  • 31,937 POSTS
Hi there,
If it is a brake warning light, check that the brake fluid is not to low, as it may be a fluid indicator warning, also best to have the brakes inspected as it may be a low pad indicator as well.
Mark (mhpautos)
Dec 12, 2007 at 7:11 AM
DOCHAGERTY
  • 9,606 POSTS
The brake light switch is in need of replacement and the indicator is telling you that you will need to replace brake pads and possibly rotors soon
Dec 14, 2007 at 4:52 PM
