1998 BMW 318 Brake Lights Out
ISLANDGIRL135
Hi everyone...
I have a 1998 BMW 318, 4 door sedan, 4 cylinder, at 120,000 miles.
The brake light don't come on. One day it didn't come on, and the next it did for a few days, and now it does not come on again.
Bulbs are good, the rest of the lights are good...Assuming it is the brake light switch.
Where exactly is the switch by the peddle? How do I get to it?
Thanks, Michelle[img:f99e57f3bd]http://www.2carpros.com/forum/automotive_pictures/117379_web__three_quarter_crop_Face_1.jpg[/img:f99e57f3bd]
Nov 13, 2007 at 3:20 PM
DOCHAGERTY
  • 9,606 POSTS
the brake light switch is just above the brake pedal. remove the Phillips screws from the under dash and the 10mm knee bolster retaining bolts to gain access. The 318 model should be part # 61-31-8-360-420 for the switch if it has two pins on the electrical connector, if it has four pins the part # is 61-31-8-360-417. pull back the red sleeve on the new switch to install. I usually break the old ones getting them out.
Nov 14, 2007 at 2:23 AM
ISLANDGIRL135
Thanks for the advice...
I will go check it out today...
When you mention "under the dash", I am assuming you mean the bottom of the dash where the brake and gas pedals come out from...
Thanks again, Michelle
Nov 14, 2007 at 8:30 AM
DOCHAGERTY
  • 9,606 POSTS
That is correct and let me know how it turns out.
Nov 14, 2007 at 10:50 AM
ISLANDGIRL135
Thanks for the time, for your advice...
I do have it changed...yeah!
Only thing is the brake light that is by the back window doesn't go on...but I know it is probably the bulb since all the other brake lights work.
Thanks again, Michelle *smile*
Nov 18, 2007 at 5:19 PM
Suggested Repair
Replace the brake light switch located just above the brake pedal. Remove the Phillips screws under the dash and the 10mm knee-bolster bolts for access. Use the two-pin or four-pin switch as required, pull back the red sleeve to install the new switch, and replace the high-mount brake-light bulb if that lamp still stays off.
Conversation Summary
The owner of a 1998 BMW 318 reported intermittent and then failed brake lights despite good bulbs and other working lights, and suspected the brake light switch. The expert said the switch is just above the brake pedal and is reached by removing under-dash Phillips screws and 10mm knee-bolster bolts, and gave the applicable two-pin and four-pin part numbers. The owner replaced the switch and confirmed the other brake lights worked; the rear-window brake light remained off and was attributed to its bulb.
