Blue smoke coming out of left exhaust
LARSANDBRO
  • 1987 CHEVROLET SILVERADO
  • 5.7L
  • V8
  • 230,000 MILES
What would be a common cause for this for this particular model (R10) and mileage?
If an engine change becomes necessary, what are the best ways of finding one? Any particular cautions or concerns?
Thanks!
Saturday, August 17th, 2019 AT 9:10 AM
SCGRANTURISMO
  • 4,897 POSTS
Blue smoke from a tailpipe usually indicates that that bank of cylinders is burning oil. The reasons for this could be a few things. You could have worn valve guides, worn oil rings, cracked cylinder head or engine block, but with the mileage on your vehicle, I would lean towards worn piston rings. A good way to test for this is to do a standard compression test on that bank of cylinders. Here is a link for you to go to explaining how to do this:
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Next, you want to take the cylinders with the lower compression and pour a teaspoon or so of engine oil into the spark plug hole and then rerun your compression test. If the compression rises from the first readings of the earlier compression test, then it is worn rings that are causing the problem.
A good place to find a good used engine, especially a Chevy 350 C.I.D. engine would be to go to eBay's used auto parts warehouse called LKQ which you can easily find on the internet. They should have any condition engine available for purchase. The main concern is staying away from an engine with higher mileage, as is the case with every vehicle that is purchased, so nothing here really changes. Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Saturday, August 17th, 2019 AT 10:35 AM
