Black smoke from exhaust pipe
190,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
WMELISSA85
It's skipping. black smoke bad carbon monoxide fumes Runs very badly. oil had gas in it..
Oct 4, 2019 at 12:17 AM
This sounds like you have a large amount of blow by. Here is a guide that talks about black smoke but the gas in the in the oil points to a larger engine issue:
https://www.2carpros.com/articles/engine-black-smoke
I would suggest running a compression check just to make sure you have a good engine. If not, then finding the excess fuel doesn't matter.
More than likely you have an injector issue over fueling which is where the smoke is coming from and it running poorly. However, if it washed the cylinder down then you will have an engine issue which should show up on the compression check.
Let me know what you find and we can go from there. Thanks
Oct 4, 2019 at 10:35 AM
