My gauges (speedometer, tachometer, gas, oil, temperature and battery) and lights turned off. I found out it might be the body control module? Everything else works fine the radio, the heat/AC. Just wondering if it is a fuse or if it is actually the BCM? Tried switching with a Tahoe BCM, did the procedure and it almost worked so I switched it back. After driving for an hour it started working again.
Apr 11, 2017 at 3:51 PM
