1995 GMC Yukon Ignition Switch
SJPKON
  • 1995 GMC YUKON
  • V8
  • 265,000 MILES
My GMC Yukon will not crank unless I put the gear in neutral and then crank it. And if I put it back in park it wont come out of park with out shutting the engine off and starting the entire cranking sequence over which means I gotta put it back in neutral and then crank the truck up. What is wrong with my ignition and transmission.
Tuesday, January 12th, 2010 AT 10:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
This is caused by a faulty Neutral / Park Safety Position Switch. It is not a tranny or ignition fault, just a bad safety switch.
Wednesday, January 13th, 2010 AT 9:11 AM
SJPKON
Bluelightnin6 thanks for the response. Would you by chance happen to know where this switch is located on one of these trucks?
Wednesday, January 13th, 2010 AT 10:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Should be located on the steering column, under the dash.
Wednesday, January 13th, 2010 AT 11:57 AM
SJPKON
Thanks again bluelightnin6. You are the best.
Wednesday, January 13th, 2010 AT 2:28 PM
