BCM problems
2002 GMC YUKON
247,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
ALLEN DYESS
how can i bypass the BCM for the A/C and wipers to work?
May 20, 2017 at 5:26 AM
SATURNTECH9
  • 30,869 POSTS
That would be a crazy bypass it is integrated to work through the BCM. Your better off having the BCM repaired there are places that can fix a BCM without having to get it programmed etc.
May 20, 2017 at 5:39 AM
WRENCHTECH
  • 20,761 POSTS
I do not know what you are being told but the BCM has nothing to do with either of those functions and they need to be diagnosed individually. https://www.2carpros.com/images/external/98965251.gif The AC depends on whether you have ATC or manual.
May 20, 2017 at 10:31 PM
