HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Truck
Engine
Idle Air Control
Replace/Remove
SPONSORED LINKS
Intake air control valve?
PREV
1
5
6
7
8
9
NEXT
UHSNOEBIRD
MEMBER
Thanks.
Thursday, March 19th, 2020 AT 5:44 AM
MECHANIC
You are welcome.
We are always glad to help.
SPONSORED LINKS
Thursday, March 19th, 2020 AT 5:47 AM
PREV
1
5
6
7
8
9
NEXT
Please
login
or
register
to post a reply.
Related Idle Air Control Replace/Remove Content
Motor Mount
How Do You Know If You Need A Motor Mount.
Asked by
dripper
1 ANSWER
1997
NISSAN TRUCK
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
Ecm Trouble
I Have A 97 Nissan Truck That Stopped Running.I Checked Fuel Pump, Ignition Fire, Timing All Good.I Tested Injectors For Pulse Nothing. Put...
Asked by
Alfred
1 ANSWER
1 IMAGE
1997
NISSAN TRUCK
1997 Nissan Truck Truck Weak
Hi I Got A 1997 Nissan Datsun Pickup It Will Start But Its Very Weak, Theres A Hole On The Throttle Body If I Cover It Dies, It Sound Like...
Asked by
fixMAcar
1 IMAGE
1997
NISSAN TRUCK
1997 Nissan Truck Tune Up Gone Wrong
Ok, So I Replaced The Valve Cover Gasket, Fuel & Air Filters, Plugs, Wires, Distributor Cap & Rotor. The Truck Feels Like It's...
Asked by
mywonderkind
1 ANSWER
1997
NISSAN TRUCK
Vacuum Hose Diagrams
I'm Looking For A Diagram Of The Vacuum Lines For This Engine. Upon Inspection, Some Vacuum Lines Are Attached And Some Are'nt....
Asked by
LumpyM
1 ANSWER
1988
NISSAN TRUCK
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Chevrolet
How to Read Codes
Code Read Retrieval/Clear Scion
Online car repair manuals
