AOD transmission installation
GAGEBUCHANAN
  • 1984 FORD BRONCO
  • 5.0L
  • V8
  • 382,722 MILES
During installation of my aod into my vehicle listed above with a 302, I noticed as I spin the motor over the weight of the explicate is catching the separator plate and will cause damage if I were to attempt running it. I've pulled the transmission back out and is still catching. All of the right parts are being used a 50 ounce offset flex-plate and the aod separator plate
Friday, September 13th, 2019 AT 10:08 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,584 POSTS
It sounds like the torque converter is not in all the way. here are two videos to help you fix the problem:
https://youtu.be/3vJAojsrfuU
and
https://youtu.be/ZC7xHVMKLRw
Please run down these guides and report back. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Monday, September 16th, 2019 AT 11:12 AM
