99 S-10 starts, won't Move
JENOLSON58
  • 1999 ALL OTHER MAKES ALL OTHER MODELS
My S10 has a manual transmission. It stopped moving suddenly. It sat for a few hours, I started it, can move the gear shift around but the truck won't move. I had the clutch replaced less than a year ago, serpentine belt was just replaced, bearings packed and sealed at the same time. Is this a tranny problem?
Saturday, April 7th, 2007 AT 9:57 PM
MIKE H R
  • 3,094 POSTS
I would say check the clutch fluid level, that works the pressure plate to disengage, with the truck in gear, engine off and the e brake off, see if you are able to push the truck by hand a little, if the clutch is working properly you should be hard to move or not move at all. If it moves freely then the clutch could be the problem.
Sunday, April 8th, 2007 AT 10:31 AM
MCFERRANCE
  • 100 POSTS
Explain "it won't move" in more detail.
Is this 4 wheel drive?
Tuesday, April 10th, 2007 AT 9:19 PM
