99 Limited 4 Runner, 75,000 miles
1999 Toyota 4Runner No Crank
99 Limited 4 Runner, 75,000 miles[/quote:a5acef1bef]
do you hear anything like the starter trying to turn the motor? Do you hear any clicks? If you do hear any of these you got problem with the starter.
If you don't hear anything at all, you might have an electrical issue.
99 Limited 4 Runner, 75,000 miles[/quote:f4f8bff9ef]
Start with Connections,the ignition switch, then the neutral safety switch/starter relay/fuse.-if all these checks out -change the starter.
Suggested Repair
Check battery and starter connections, the ignition switch, neutral safety switch, starter relay, and fuse. If those check out, replace the starter. If there is no click and electrical behavior is odd, also have a stock or aftermarket alarm checked for interference.
Conversation Summary
The owner of a 1999 Toyota 4Runner Limited with 75,000 miles reports an intermittent no-crank condition. Electrical accessories still work, and cycling the key several times eventually allows a normal start. It is not tied to weather. Replies suggest distinguishing a clicking or spinning starter from a silent electrical fault, and one owner reported a similar issue caused by a stock alarm. Another owner blamed a heat-related starter problem. The expert recommends checking connections, the ignition switch, neutral safety switch, starter relay, and fuse, then replacing the starter if those parts check out.
