99 Grand Prix 3.8 SC won't start
JIMBITNER
  • 1999 ALL OTHER MAKES ALL OTHER MODELS
Car has been running fine. Went out this AM and it cranks but won't start. Checked fuses-what's next?
Tuesday, April 10th, 2007 AT 3:57 PM
MCFERRANCE
  • 100 POSTS
Listen at the gas tank filler while someone turns the key on, you should here the fuel pump run. If not, have them crank the engine and let off leaving the key on. You again should hear the pump run. If not, then check fuel pump fuse and relay.
Wednesday, April 11th, 2007 AT 7:33 PM
