1999 Chevrolet S10 Won't Shift
1999 ALL OTHER MAKES ALL OTHER MODELS
TMASON
I have a 99 Chev. S10 4WD pickup with 147,000 miles. At times when I put the truck in drive and accelerate the odometer does not work, the auto transmission will not shift and then the ABS light will come on. I think it may be the speed sensor. Where is it located?
Apr 14, 2006 at 3:53 AM
LOSONE
  • 1,616 POSTS
It is located at the back of the tranny. It will have a twisted pair of wires, probably yellow and purple. It could be your problem Good Luck
Apr 14, 2006 at 3:57 AM
Suggested Repair
Inspect the vehicle speed sensor at the rear of the transmission. It uses a twisted pair of wires, likely yellow and purple, and a faulty sensor may explain the no-shift, odometer, and ABS symptoms.
Conversation Summary
The owner of a 1999 Chevrolet S10 4WD with 147,000 miles reports intermittent no-shift in Drive, a nonworking odometer, and an ABS light, and suspects the speed sensor. The expert says the sensor is at the back of the transmission, with a twisted pair of wires that are probably yellow and purple, and that it could be the cause.
