It was working fine, and just quit, all works but the clutch will not engage. I shure would appreicate some help. I am new at this and may not do it all right. thanks. :D [/b]
2010 Chevrolet S-10 AC Clutch Won't Engage
but the clutch still will not kick in. Every thing seems to work ok except the clutch, it just don't engage. Thanks in advance for your response. :)
Suggested Repair
Verify the refrigerant charge correctly before replacing the clutch. A blue gauge reading with the system off indicates a very low charge; the compressor must be running for that reading to be meaningful. Low refrigerant opens the low-pressure cycling switch and prevents clutch engagement. Also check power from the A/C switch through the relay to the pressure switch and clutch.
Conversation Summary
The owner of a 2010 Chevrolet S-10 said the air-conditioning clutch stopped engaging while the rest of the system appeared to work. The expert explained that the A/C switch energizes a relay, which feeds the low-pressure cycling switch, and that adequate refrigerant pressure is required to complete the clutch circuit. After the owner reported a blue gauge reading, the expert said the reading is only valid with the system running and that blue with the system off means the refrigerant charge is very low.
