2000 Chevrolet S-10 Shift Bang
2010 GMC
MPTIMKO
I have a 2000 s-10 4x4 pickup ext. cab 4.3 v6. with 112,000 miles on it. I have had a problem with the check engine lite coming on and it saying the codes says check the transmission computer. But anyways what is happening is that when you drive it from a stop, I hits that first shift point and it bangs HARD. But not all the time or any other gear. I was told to replace the filter and then a solenoid and then the seals...... Help. Also when I use my 4 wheel, it doesn't shift easily from 4 wheel high to 2 wheel easily, it also bangs loudly.. HELP!!!!!!!!!!!!!!!!!!!
May 5, 2006 at 2:11 PM
LOSONE
  • 1,616 POSTS
You need to have a tranny expert look at it. Your tranny won't last long with that problems it goes into "limp back" mode and is not for driving--just limping back home.
May 6, 2006 at 2:57 AM
Suggested Repair
Have a transmission specialist inspect the transmission promptly. Avoid continued driving while it is in limp mode, which is only meant to get the vehicle home and can shorten transmission life. Filter, solenoid, and seal replacement were suggested to the owner but not confirmed by the expert.
Conversation Summary
The owner of a 2000 S-10 4x4 with a 4.3 V6 reports a check-engine light referring to the transmission computer, a hard bang on the first shift from a stop, and a loud bang when shifting from four-wheel high to two-wheel drive. An expert advised having a transmission specialist inspect it and warned that limp mode is not for normal driving.
