1995 Pontiac Grand Am Clicking Noise
1995 ALL OTHER MAKES ALL OTHER MODELS
SLYDOG
Just replaced right front hub assembly and car makes noise when turning hard right .
what could I have done wrong?
Apr 15, 2006 at 10:52 AM
LOSONE
  • 1,616 POSTS
No idea but is it a "clicking noise?"
Apr 15, 2006 at 11:04 AM
SLYDOG
Yes clicking noise
Apr 15, 2006 at 11:18 AM
LOSONE
  • 1,616 POSTS
You have a bad outer CV joint. Good luck
Apr 15, 2006 at 12:13 PM
SLYDOG
It didn't make noise before I replaced the hub
Thanks
Apr 15, 2006 at 1:14 PM
LOSONE
  • 1,616 POSTS
May be not but CV's are the only thing that clicks when you turn the wheel. It may have failed as a coincidence. Good luck
Apr 15, 2006 at 1:39 PM
Suggested Repair
Inspect and replace the outer CV joint. A clicking noise when turning hard is typical of a failed outer CV joint, which may have failed around the same time as the hub replacement.
Conversation Summary
After replacing the right front hub assembly on a 1995 Grand Am, the owner heard a clicking noise when turning hard right that was not present before the repair. The expert said a clicking noise while turning indicates a bad outer CV joint and that the failure may have been coincidental.
