2003 Grand Am Squeak and Clunk
2003 ALL OTHER MAKES ALL OTHER MODELS
ANGELASHLEY
We purchased my car new about 2 years ago and haven't had any major problems with it. I wrecked it about 6 months ago and had to have everything (or at least i think they replaced everything) on the front passenger side replaced. Well after i got it fixed there was a noise and i had to have an axle replaced (which was supposed to be fixed after the accident). I got the car back after having a new axle put in it and i started hearing this really loud noise that sounds like a squeaky chair coming from the front passenger side. i take the car back they say they can't hear anything but they replace an intermediate shaft anyway (they also strip a screw while doing this). to make a long story short, my warranty has expired, all the times i took my car back to the dealer about the noise they never fixed it, and my car still has this noise. It also sounds as though there is something "loose" in the same area of the car when i go over bumps. The noise doesn't happen all the time, which makes me seem crazy sometimes when i'm trying to get someone to hear it. Any help would be much appreciated. Thanks!
Feb 2, 2006 at 1:19 PM
CHEVY350GUY
  • 109 POSTS
can you list what was replaced? an intermittant noise is one of the hardest problems to find, so if you know what was replaced it would help.because it could be anything. is it always squeak, or si there a clunk, or slight rattle that sometimes accompanies it.
Feb 3, 2006 at 12:31 AM
ANGELASHLEY
okay on the bill that i recieved back they have listed a rod kit, arm, sheild, clamp, fascia, headlight, fender, tire, wheel. They later replaced a wheel hub, bearings, intermediate shaft, and axle. i hope that helps. THe noise is like a squeaky bed. i know its comming from that side, but it doesnt happen all the time, some days i hear it other days i dont. THere is also a kinda of louder noise, kinda like a low-pitched clunk that sounds like something is loose. that noise happens all the time when i go over small bumps. both noises are in or around the same place, i know that they are comming from the front passanger side. Which just happens to be the side that was wrecked. Thanks
Feb 5, 2006 at 12:16 AM
MVANNESSJR
  • 223 POSTS
Check the strut and strut tower. There isn't much left on that side that could be causing the odd sound assuming they replaced those other parts properly. The strut moves up and down with the car and it may be causing some of the noise.
Feb 5, 2006 at 5:23 AM
ANGELASHLEY
thanks for all the help
Feb 6, 2006 at 12:50 PM
Suggested Repair
Inspect the front passenger strut and strut tower. With the other listed parts already replaced, the strut's up-and-down movement is a likely source of the intermittent squeak and the clunk over bumps.
Conversation Summary
A 2003 Grand Am developed an intermittent squeak like a squeaky chair and a low-pitched clunk over bumps on the front passenger side after collision repairs. Replaced items included a rod kit, arm, shield, clamp, fascia, headlight, fender, tire, wheel, wheel hub, bearings, intermediate shaft, and axle, but the noises continued and the dealer could not reproduce the squeak. An expert advised checking the strut and strut tower, noting little else remained on that side if the other parts were installed correctly.
