2000 Pontiac Grand Am Dash Clicking
LESLIE
My 2000 Pontiac Grand Am has about 135000 miles on it. I bought it used. As of yesterday this clicking noise started coming from the dash. Each time i turned my turn signal on I would only hear the turn signal, but as soon as I made the turn the clicking would increase and get louder. Has anyone experienced this? Any thoughts?
Mar 29, 2006 at 1:59 AM
KENB79764
  • 52 POSTS
your turn signal relay may be beginning to short out. it will be in the fuse block under your dash and give you these symptoms
Apr 5, 2006 at 2:52 AM
Suggested Repair
Check the turn signal relay in the fuse block under the dash; it may be beginning to short out and should be replaced if faulty.
Conversation Summary
A 2000 Pontiac Grand Am owner reported a clicking noise from the dash that is heard with the turn signal and gets louder after a turn. An expert said the turn signal relay in the under-dash fuse block may be beginning to short out and can cause these symptoms.
