1999 Grand prix 3.8
1999 ALL OTHER MAKES ALL OTHER MODELS
VIPER
I have a 1999 Grand prix GT . I can not remove key or put vechicle into park. i need to hit the over ride switch at the underneath area of steering colum and shift lock switch to have the key and floor shift operate. I noticed that the actual shift indicator lights also work so times and other times will not illuminate . when the vechicle is work the shift work .
I have taken apart the shifter and tested everthing there and it all works . Could it be the switch at the transmisson that the shaft of the for lack of better terms "shift rod" be bad?? The switch is located at top of the transmisson and has several wires in a harness attached to it and the linkage for the shifting rod goes through it . Help my wife is kiiling me with her griping about have to use a gilf tee to over ride the two options . Thank you Eric
Dec 11, 2006 at 2:53 AM
CARUNDELL
  • 602 POSTS
[quote:667deff0be="viper"]I have a 1999 Grand prix GT . I can not remove key or put vechicle into park. i need to hit the over ride switch at the underneath area of steering colum and shift lock switch to have the key and floor shift operate. I noticed that the actual shift indicator lights also work so times and other times will not illuminate . when the vechicle is work the shift work .
I have taken apart the shifter and tested everthing there and it all works . Could it be the switch at the transmisson that the shaft of the for lack of better terms "shift rod" be bad?? The switch is located at top of the transmisson and has several wires in a harness attached to it and the linkage for the shifting rod goes through it . Help my wife is kiiling me with her griping about have to use a gilf tee to over ride the two options . Thank you Eric[/quote:667deff0be]
Hey Eric,
Your shifter interlock is actuated by either the brakelight switch (on your pedal) or an additional switch next to the brake light switch. try checking the connections there and its operation, additionally was the solenoid at the shifter good?
Chris
Dec 11, 2006 at 4:24 AM
VIPER
The solieniod is good @ shifter
Does that switch control the key
The key will not return to its place to take it out
until you hit the release under steering colum
Dec 11, 2006 at 4:44 AM
CARUNDELL
  • 602 POSTS
[quote:9fcf3e4bea="viper"]The solieniod is good @ shifter
until you hit the release under steering colum[/quote:9fcf3e4bea]
ummmmmm I think putting shifter in park controls that lock on the steering/key. I want to say a micro switch in the shifter assembly. But I'm not 100% positive How bout it GM techs, any body??
Chris
Dec 11, 2006 at 4:57 AM
