99 dakota transmission trouble
1999 ALL OTHER MAKES ALL OTHER MODELS
GKBOST
I have a 99 Dakota automatic transmission, 3.9 v6 The truck has 64xxxx miles. The first couple of times through the gears it has a hard time getting from 2nd to 3rd. all other gears are fine. After engine heats up the problem goes away. Transmission or filter/fluid?
Feb 28, 2007 at 6:32 AM
CHEVY22
  • 1,375 POSTS
you could try a flush but this one sounds internal , possibly the pump or converter going south , but if the fluid is dirty try the flush first and go from there , if you need more help let us know and if the engine light is on have it checked and get back to us
thanks , jim
oh and if you are happy with the info please leave some feedback we all donate out time here helping people for free
Feb 28, 2007 at 6:52 AM
SHORTYBOY
  • 7 POSTS
I too have a transmission problem.
In high gear, there seems to be a bounce in the RPM's, especially when I hit bumps or accelerate. I am hoping this is caused by a faulty solenoid or sensor somewhere. Currently I am getting a P0505 code which pertains to the idle speed motor. I cleaned this with Carb cleaner, and the transmission problem has only happened since this cleaning. Could a new Idle sensor be the fix?
Any help is greatly appreciated.
Shorty.
Feb 28, 2007 at 10:24 PM
CHEVY22
  • 1,375 POSTS
yes always replace them , the problem is the circuit is malfunctioning meaning it is shorting internally and clear the codes and see what happens and get back tp ud
jim
Feb 28, 2007 at 10:32 PM
SHORTYBOY
  • 7 POSTS
Sorry,
Not all that mechanically inclined...What do you mean by TP UD?
Feb 28, 2007 at 11:32 PM
CHEVY22
  • 1,375 POSTS
sorry typo i meant get back to us , replace the iac
jim
Mar 1, 2007 at 12:08 AM
GKBOST
just checked the fluid ... it appears clean and doesn't smell. My local mechanic says the transmission has to be replaced..then he asked me how much I wanted for mt truck. ?????
Mar 1, 2007 at 2:16 AM
CHEVY22
  • 1,375 POSTS
get a second opinion and replace that iac before you do anything , just my opinion
thanks , jim
Mar 1, 2007 at 3:42 AM
