1999 s600 v12 3600k
1999 ALL OTHER MAKES ALL OTHER MODELS
FLYG72
I have a v12 engine 1999 s600 and at the front center of the engine under a Mercedes plastic cape I found a reservoir. I don’t know what goes in it and it is empty is it power steering or transmission fluid? Can someone give me a clue since I can’t find it in the manual. :? :?
Apr 10, 2007 at 8:51 AM
GFIMOTORCARS
  • 673 POSTS
This is more than likely your power steering reservior. If you have ABC suspension however you may be looking at the ABC reservior.
Jan 4, 2009 at 3:32 AM
COOLPHIL
  • 12 POSTS
it is the reservoir for your power steering fluid, all V12 WDB140 have the same configuration when it comes to location of ATF reservoir. if it is empty then fill with proper grade ATF dexron III and purge if your reservoir has dried out, question: did you check if there was leaks either on the hose line or on the pump and maybe on the steering box? It is not normal to have an empty resevoir.
May 24, 2009 at 10:59 PM
