1994 Trans Am coolant overflow
1994 ALL OTHER MAKES ALL OTHER MODELS
TRACYFEATHERS
Just rebuilt 5.7L v8 for 1994 Firebird Trans Am. After hitting 100 miles on rebuilt engine, overheated and Low Coolant light came on. Changed the Coolant Temp Sending Unit and Coolant Temp Sensor, thermostat, radiator cap. Light went off, all was thought to be well. However, when I give it gas (whether driving or parked) coolant gushes out the overflow resevoir. I have checked coolant levels, burped all air out, checked hoses (No holes, leaks, etc.) but discovered hose leading from radiator to bleeder valve is bone dry. Didn't find any blockages in the hose, but can't understand why is shoots water out the resevoir but no watter present in the overflow hose. Any help would be greatly appreciated. Thanks in Advance!
Aug 9, 2006 at 3:30 PM
MIKEYBDMAN
  • 623 POSTS
[quote:fade0837ec="TracyFeathers"]Just rebuilt 5.7L v8 for 1994 Firebird Trans Am. After hitting 100 miles on rebuilt engine, overheated and Low Coolant light came on. Changed the Coolant Temp Sending Unit and Coolant Temp Sensor, thermostat, radiator cap. Light went off, all was thought to be well. However, when I give it gas (whether driving or parked) coolant gushes out the overflow resevoir. I have checked coolant levels, burped all air out, checked hoses (No holes, leaks, etc.) but discovered hose leading from radiator to bleeder valve is bone dry. Didn't find any blockages in the hose, but can't understand why is shoots water out the resevoir but no watter present in the overflow hose. Any help would be greatly appreciated. Thanks in Advance![/quote:fade0837ec]
Im trying to understand, but what you are saying is a little confusing. The bleeder vent should be located on the water outlet tube right over your thermostat. If that hose is dry, then your thermostat is not opening, or you have a blockage in your engine. Another possible cause could be a sheared water pump, however odd that may be.
Now, since you say the water is gushing out when you accelerate indicated that maybe it is a blockage and the water pump is back pressurizing the radiator making the water flow out of the severvoir. Of sourse you then said the over flow tube was dry, which makes no sense if that is the only hose connected from the radiator to the resevoir.
Blown head gasket keeps rattling in the back of my mind also, but hopefully it isnt that major.
Aug 11, 2006 at 12:08 PM
JAMESONEY
  • 7 POSTS
Hey, I have somewhat of the same problem. I have had coolant leaking from my radiator so I replaced the radiator. After I did that, coolant began to shoot out of my reservoir. I then replaced the radiator cap and the thermostat; however, the problem still persists. What do you think could be the problem?
Oct 15, 2012 at 5:51 AM
JAMESONEY
  • 7 POSTS
Sorry about that. I have a 2003 Kia Spectra (DOHC 1.8)
Oct 15, 2012 at 5:52 AM
