1994 Topaz Major Coolant Leak
1994 ALL OTHER MAKES ALL OTHER MODELS
TOPAZ
I went to warm up my car the other day and noticed a major coolant leak on the passenger side. it was pouring out. I turned off the car and opened the hood, noticing the resevoir was bone dry. When i looked under the car i think i seen it comming from a metal pipe that ran up into something that i counlt see.
I have noticed very small leak in the past and brushed it off. The motor never overheated either.
I am wondering what this could be? and where exactly it is leaking. could it be a water pump? if so what is the general cost to have it fixed in a shop?
Jan 28, 2006 at 5:42 AM
LOVESCARS
  • 359 POSTS
Is the inside of the automobile passenger side carpet also getting wet/damp or is it just outside underneath the car?
Jan 28, 2006 at 1:22 PM
TOPAZ
hello, it was under the car. There is nothing in the car if this helps
Jan 29, 2006 at 9:21 AM
LOVESCARS
  • 359 POSTS
Could be the radiator or one of your radiator hoses. check all connections to be sure they are tight and check hoses for any ruptures.
If the radiator is leaking you should be able to tell fairly easily.
Jan 29, 2006 at 9:41 AM
GODBEAR839
  • 77 POSTS
The part you couldn't see is the heater core make sure the "pipe" isn't broken or doesn't have a crack in it also make sure the hose is good and tight on there if you still have the original clamps maybe put another clamp on it.
Jan 30, 2006 at 12:55 AM
Suggested Repair
Inspect the passenger-side radiator, radiator hoses, and the heater-core metal pipe and hose connection. Confirm clamps are tight, add a clamp if the original one is loose, and replace any ruptured hose or repair a cracked pipe or leaking radiator if found. A water pump was not confirmed, and no shop cost was given.
Conversation Summary
The owner of a 1994 Topaz reported a major passenger-side coolant leak under the car from a metal pipe leading upward, with a dry reservoir and no interior wetness or overheating. One expert suggested checking the radiator and radiator hoses for loose connections or ruptures. Another identified the unseen area as the heater core and advised checking the pipe for cracks and securing the hose, adding a clamp if needed.
