91 ranger 2.3 coolent temp sensor not working right
1991 ALL OTHER MAKES ALL OTHER MODELS
WESMAN2440
  • 23 POSTS
hey I have a 91 ranger 2.3 liter, and the coolant sensor was not working at all, so today I replaced it myself and I idled it to see if it was working right and it read up to the center mark and as usual the thermostat kicked in and it went back down, well that was the last time it read that high.....Now it barely reads anything and it barely goes up even when I drove it all over town and idled it until the engine got real hot and still it just read cold ......I don't quite know what to do or whats wrong with the thing,,,,,, can anyone help that knows something ??????
May 17, 2007 at 2:24 PM
AUTOPOP
  • 49 POSTS
Check for bad connection at temperature sender unit and wiring clip clean it if it's needed and apply little grease before connecting it back.
May 18, 2007 at 5:35 AM
RUDPRO
  • 224 POSTS
Dosconnect the wire at the sending unit. Use a jumper wire, connect the wire to a clean ground. Turn the ignition on without starting the engine. If the gauge reads hot the sending unit is bad. If the gauge doesn't work, the circuit may be open, may even be a fuse, or the gauge itself is bad.
May 18, 2007 at 5:49 AM
WESMAN2440
  • 23 POSTS
thanks I'll try that and I'll let you know how it go's
May 18, 2007 at 6:21 AM
RUDPRO
  • 224 POSTS
Sorry, I was looking at an older wiring diagram, one wire going to the sensor. I believe there should be two wires going to the sensor,a light green/red and a gray/red. Turn the key on,engine off, disconnect the wires, look at gauge. It may read all the way hot or cold. Jumper the two wires in the plug together and check the gauge, it should have swung one way or the other. Ground one wire in the plug, check gauge, and do the same to the other wire. You should see movement of the gauge. When jumpering wires together and to ground do it briefly. If gauge doesn't respond it's bad. Also, do you think the thermostat is sticking. If it's stuck open, that would make the temperature gauge read low all the time.
May 18, 2007 at 9:27 AM
WESMAN2440
  • 23 POSTS
Hey yea I have givin thought to the thermostat stickin open because the guage works but I know that its not working right and my heater is barely hot so iv given thought to the thermostat and Im gonna check it and see and im gonna replace it cuz i mean it dont cost that much and i'll just see if its that....
But thanks for your help I appreciate it alot because im brain dead right now haha ...........I'll keep you notified
May 18, 2007 at 11:44 AM
