Hi camgirl,
Thank you for the donation.
If the starter cannot be cranked, then it coudl be the main fuses or the ignition switch.
If it cranks and cannot fire up, then you need to check what is missing, either ignition sparks or fuel.
Is the vehicle working now and they could not find the cause or the vehicle is still not able to start?
SPONSORED LINKS
Monday, April 5th, 2010 AT 11:55 AM
