1999 Acura TL Stalls while running
SCAMPBELL63
  • 1999 ACURA TL
  • 6 CYL
  • 165,000 MILES
I have Acura that runs great but peiodically will stop running while in motion. Vehicle does not chug or spit and all pwoer is lost immeidately. Vehicle usually restarts but lately hs been difficult to restart. During restart power comes up and then immeidately goes off. I replaced one battery terminal 6 months ago and some corrison is in place but again when vehicle is cold it always starts. Any ideas?
Thursday, October 22nd, 2009 AT 10:36 AM
KHLOW2008
  • 41,814 POSTS
Hi scampbell63,
Thank you for the donation.
Symptoms seems to describe a fault with the ignition switch.
There was a safety recall for the item. Call the nearest dealer to check if your vehicle qualifies for the recall.
Thursday, October 22nd, 2009 AT 11:32 AM
SCAMPBELL63
Can you explain to me how an ignition switch would call cr to stall after it is running?
Thursday, October 22nd, 2009 AT 11:47 AM
KHLOW2008
  • 41,814 POSTS
The ignition switch is the main power switch for the engine and due to some defect in the design, it tends to lose contact intermittently, usually after heating up due to usage, and when this occurs, it would be as if the engine has been turned OFF.
When trying to start, the engine might start up but when the key is released, the engine would stall.
A few cranks might get the contact back in position and the engine would work well again.
It can fail under any driving conditions.
Thursday, October 22nd, 2009 AT 12:47 PM
