Hot engine stalling. When the engine is at running temperature and is turned off, if I leave it for 5-10 minutes I have a hard time starting it again. It wants to stall and I have to rev up the engine for 20-30 seconds so that I can put in gear without stalling. The problem is intermittent. Cold weather starts are OK. Sometimes the engine revs up for no reason for a short period of time. This problem started before I cleaned the exhaust manifold runners. The runners were plugged but have been thoroughly cleaned.
On a separate issue, sometimes when it is very hot outside the air conditioning will not come on or come on for a short period of time. When the temperature is cooler there seems to be no problem.
SPONSORED LINKS
Wednesday, February 10th, 2010 AT 8:32 AM
