1999 Acura TL stalling
CARROKE
  • 1999 ACURA TL
  • 6 CYL
  • 113,000 MILES
The engine check light came on, and shortly thereafter, the car stalled out while going 30 mph. After several atempts to restart, it started, and after about 30 seconds, it stalled out again. After a couple of more minutes, it started again, and I drove 3 miles to my home, with the check engine light still on. What might the problem be?
Sunday, November 1st, 2009 AT 8:05 AM
KHLOW2008
  • 41,814 POSTS
Hi carroke,
Thank you for the donation.
When the CEL comes on, an error has been detected in the engine management system and you would need to retrieve the trouble codes to understand what is causing the problem.
Get a free scan done at Autozone and let me know the exact trouble codes retrieved.
We can proceed from there.
Sunday, November 1st, 2009 AT 9:06 AM
CARROKE
The code was P0420
Sunday, November 1st, 2009 AT 2:42 PM
KHLOW2008
  • 41,814 POSTS
P0420 = Catalyst System - Efficiency below threshhold.
The fault code indicates a bad catalytic converter. It could be clogged causing the engine to stall when you try to accelerate.
The engine stalling and difficult to start could be related or it could be something else and sine P0420 has been detected, you would have to get it rectified before continuing with diagnostics if the problem persists.
Monday, November 2nd, 2009 AT 6:38 AM
