Description of the symptoms are not sufficient to understand the problem so I hope you can elaborate more on it and provide as much details as possible.
If the Check Engine Lamp is indicating, you would need to retrieve the trouble codes to proceed with rectification.
Did problem start only after the accident?
It could be a fuel supply problem and a pressure test would help to find out if that is the cause.
Friday, October 1st, 2010 AT 4:09 PM
