Recently we had our battery and oil changed at valvoline and the next day our car over heated and split a hose. We replaced the hose at a local repair shop, but two days later the car was overheating again. After letting it cool a bit, we started the car only to have it stall out immediately. We took it to the dealership and they found a hole in the new battery that had been replaced by valvoline. The dealer checked for any additional damage and returned the car. On the way home from the dealership, the car overheated once again. They said it had no fluid, we need a new radiator, and they need to check the engine for severe damage. How did getting a new battery lead to all this trouble? Is the repair shop responsible for letting us drive a car they said was fixed? What happened? Please help. :( Lovelee
1998 Acura RL Overheating After Battery
My guess is there was a problem on the horizon before the battery was replaced. I fear a headgasket situation that caused the hose to split and the radiator to rupture. The cylinders are probalby exposed to the cooling system and pressurizing it. I don't know where the dealer was coming from when they tied the overheating into a hole in the battery. That hole in itself sounds strange.
Suggested Repair
Have a qualified independent shop pressure-test the cooling system and check for a blown head gasket that is letting combustion pressure into the coolant. That can split hoses, empty the radiator, and cause repeated overheating. Do not treat the battery hole as the cause, and avoid driving the car until engine damage is assessed.
Conversation Summary
A 1998 Acura RL overheated and split a hose the day after a battery and oil change. A replacement hose did not stop the overheating, and the car later stalled. A dealer found a hole in the new battery, returned the car, then said it had no coolant, needed a radiator, and should be checked for severe engine damage. The expert doubted any link between the battery hole and the overheating and suspected a pre-existing head gasket problem pressurizing the cooling system.
