1998 acura 3.5 RL where is the starter relay located?
1998 ALL OTHER MAKES ALL OTHER MODELS
MIKEYBDMAN
  • 623 POSTS
There is a starter cut relay located under the dash on the drivers side inside the Under-dash fuse/relay box.
You can test this relay.
Check for continuity between the terminals.
There should be continuity between the No.1 and No.3 terminals when power and ground are connected to the No.2 and No.4 terminals.
There should be no continuity between the No.1 and No.3 terminals when power is disconnected.
Aug 14, 2006 at 12:04 PM
MIKEYBDMAN
  • 623 POSTS
[quote:164876ade4="calexwill"]where is the starter relay on located on this car?[/quote:164876ade4]
CALEXWILL
Aug 14, 2006 at 4:35 PM
