1996 Acura RL White Smoke at Idle
GENJIANB
I have 1996 Acura RL with 180,000 miles on it. It has a 3.5L V6 and is an automatic. For a while white smoke has been coming out of the tail pipe while the car sitting at a stop light or a drive through for a few minutes. But lately it has gotten worse. However, the smoke goes away after I accelerate. It now happens every time the car is idling. Sometimes the smoke has bluish tinge to it, and there is a very thin layer of soot of the back bumper that I can wash off. The coolant level is at full in the reservior. But the engine does consume oil because I always have to put a quart in after about a 1000 miles and I do not know if that fills it all the way up. I also use smoke be gone, and that at first helped, but now it is not. The oil is not milky. It actually looks the same the day I got the oil changed. I use the car to drive to college everyday. Readding from some of the other post I think I have a head gasket problem. Please help!!
Thank you
Aug 23, 2007 at 3:05 PM
  • 75,988 POSTS
[quote:0e1e1146dc="genjianb"]Hi,
Thank you[/quote:0e1e1146dc]
Its a sign of coolant burning in the combustion chamber could be the gasket/head/block-Have it pressure tested to identify where the actual leak is.
Aug 23, 2007 at 10:29 PM
Suggested Repair
Have the cooling system pressure tested to locate the leak. White smoke at idle that clears under acceleration can indicate coolant entering the combustion chamber from a head gasket, cylinder head, or engine block.
Conversation Summary
The owner of a 1996 Acura RL with 180,000 miles reports white exhaust smoke at idle that clears after acceleration, sometimes with a bluish tint and light soot on the bumper. Coolant stays full, the oil is not milky, and the engine uses about a quart of oil every 1,000 miles. An additive initially reduced the smoke but no longer helps. The expert says this can mean coolant is burning in the combustion chamber and recommends a pressure test to determine whether the leak is in the head gasket, head, or block.
