1996 Acura RL Maintenance Light
JASONB37
I had a 1996 Acura RL with 150,000. The maintenance required light is lit up I had it checked out by rep dealer I'd know what the problem is and at this time choose not to fix it for financial reasons and will do so later. But in the meantime I wish to turn the light off I know how to turn off the check engine light but cannot find the fuse or do not know the code to turn off the maintenance required light how can I do this
Aug 25, 2007 at 2:16 AM
BRUCE HUNT
  • 3,754 POSTS
Two seperate lights. Maintenance light goes off about every 10k miles. Reset is in the owners manual. Usually key off and holf the reset on the trip odometer and turn the switch to the on position and hold for about 10 seconds. It should go off. The check engine light is different and it is turned off by a diagnostic tool or by pulling main fuse. But I would want to know what the code is myself. I suspect your looking at a cat or O2 replacement.
Aug 29, 2007 at 9:29 AM
Suggested Repair
Reset the maintenance required light with the trip odometer: key off, hold the trip reset button, turn the key on, and hold about 10 seconds until the light goes out. The check engine light is separate and should be diagnosed by code rather than simply cleared; a catalytic converter or oxygen sensor may be involved.
Conversation Summary
The owner of a 1996 Acura RL with about 150,000 miles wants to turn off the maintenance required light after a dealer inspection, while postponing repairs. The expert explains that this light is separate from the check engine light and typically comes on about every 10,000 miles. It can be reset by holding the trip odometer reset button while turning the key on for about 10 seconds. The check engine light requires a scan tool or fuse pull to clear, and the expert suspects a catalytic converter or oxygen sensor issue.
