1996 Acura RL Maintenance Light
Suggested Repair
Reset the maintenance required light with the trip odometer: key off, hold the trip reset button, turn the key on, and hold about 10 seconds until the light goes out. The check engine light is separate and should be diagnosed by code rather than simply cleared; a catalytic converter or oxygen sensor may be involved.
Conversation Summary
The owner of a 1996 Acura RL with about 150,000 miles wants to turn off the maintenance required light after a dealer inspection, while postponing repairs. The expert explains that this light is separate from the check engine light and typically comes on about every 10,000 miles. It can be reset by holding the trip odometer reset button while turning the key on for about 10 seconds. The check engine light requires a scan tool or fuse pull to clear, and the expert suspects a catalytic converter or oxygen sensor issue.
