2003 Honda Civic Maintenance Light
BAYLORBYRNE
I have a 03 Honda Civic and when I turn the car on the maintenance light turns stays on for approx 15 secs (about 5-10 seconds after all of the other lights go off). Should I bring it into a car mechanic or is it something that I can repair.
Mar 18, 2007 at 9:16 AM
BRUCE HUNT
  • 3,754 POSTS
That light is a warning that your next service should be performed. I personally would love to kill the darn thing. It is set to go off I think every 10,000 miles. It will eventually turn red and stay on. To clear it the process is in the owner manual. They state that if the mechanic forgets, this is how you reset it.
With the key off, push and hold the reset odometer button, turn the key to the on position without starting the vehicle and hold that reset button until the maintenance light goes out.
It will be back. It is YOUR call when that vehicle should be serviced. Don't be alarmed by that light.
Mar 19, 2007 at 6:02 AM
Suggested Repair
Treat the light as a scheduled service reminder, not a fault. Reset it with the key off by holding the odometer reset button, turning the key to ON without starting, and holding until the light goes out. Service the Civic on your own schedule; the reminder will return.
Conversation Summary
The owner of a 2003 Honda Civic asked whether a maintenance light that stays on about 15 seconds after startup needs a mechanic. The expert explained it is a service reminder, typically set around every 10,000 miles, and described the owner-manual reset procedure. The light will come back and is not itself a reason for alarm.
