2005 Honda Civic
MTS.COM
  • 2005 HONDA CIVIC
  • 4 CYL
  • FWD
  • 110,123 MILES
How to reset maintenance required light
Friday, August 6th, 2010 AT 12:04 AM
KHLOW2008
  • 41,814 POSTS
Hi mts. Com,
Here are the procedures.
MAINTENANCE REQUIRED REMINDER LIGHT/ENGINE OIL LIFE INDICATOR RESET - PROCEDURE 3
1. For the first 8000 miles after maintenance required indicator is reset, the MAINT REQ'D indicator light illuminates when the ignition is turned on, then will go out after 2 seconds. When mileage is 8000-10,000 miles, the MAINT REQ'D reminder light will illuminate for 2 seconds, then blink for 10 seconds, and then go out. When mileage exceeds 10,000 miles, MAINT REQ'D indicator light illuminates and stays on while ignition switch is in ON (II) position.
2. To reset the MAINT REQ'D indicator light, turn ignition switch to OFF position. Press and hold the SELECT/RESET button. While still holding button, turn ignition switch to ON position, with engine off. Hold SELECT/RESET button for about 10 seconds until indicator resets.
3. If MAINT REQ'D reminder light does not reset, ensure headlights, parking lights, or both are turned off when resetting reminder light. The MAINT REQ'D indicator cannot be reset if any of these lights are on. If vehicle is equipped with daytime running lights and lights come on when ignition switch is turned to ON (II) position, daytime running lights must be disabled before indicator light can be reset.
Friday, August 6th, 2010 AT 3:20 PM
